HighLineCBR
Thread starter- Joined
- Jul 6, 2008
- 104
I have a 23' cuddy cuddy boat. I had the bottom soda blasted and now need to seal and repaint the bottom.
I would rather not do this on the trailer but instead block the boat which woulod allow me easier access.
First i planned to block the boat using cinder blocks. Then someone told me that cinder blocks may crack easily and that this would not be a safe sollution for the boat or for me working under it.
Then i decided to build stands from wood. But now I am being told not to attempt removing the boat from the trailer in my driveway. Its dangerous and if i make a mistake, the boat may easilly fall off the stands and cause a disaster.
what are your oppinions on this issue? SHould i just do the work on the trialer, its no easy task but i guess i could move the boat back and forth on the rollers to ge to all the areas...
thanks,
Luke
thanks,
Luke
