reiddo1
Thread starter- Joined
- Jan 17, 2012
- 166
I have a (new to me) 1979 Evinrude 200 hp V6 which blows fuses when I use the choke solenoid on a cold start. This fuse is next to the starter solenoid and is 30 amp. I suspected that the solenoid was the problem but with it electrically disconnected the fuse will still blow when the choke/key button on the control box is pushed in. I can get around the problem by manually choking the engine on a cold start but that means engine cover removal each time. Any ideas would be appreciated. I will be pulling the circuit apart starting at the control box for each connector and working toward the stern. Anyone with similar problems in the past? Thanks for reading..................Don
