Re: blown #6 cylinder on Johnson 225
We got things torn apart and discovered #6 cylinder(bottom left) would funtion with low compression but had a piston that was broken apart. Shards of metal were compressed into the head/cover. We also discovered scarring on cylinder number two possibly from a pin according to iboat forums.
options were the following:
Rebuild motor on our own for first time and hope it works. Cost $1500
Buy a used motor for $3500-$5000 that is slightly newer but then also pay $1000 for new controls. (I was told anything newer than 1995 would require new guages and controls)
Option we chose- buy rebuilt power head for $1800 out of Rico Beach NY with a one year warranty. Install it ourselves and replace all critical parts such as rebuild carbs, replace thermastats, new water pump, and new gaskets and seals for entire engine.
Two major questions.
1. We had a hard time getting fly wheel off and broke two pullers. When it finally did come off it cracked like a gun shot and flew into the air.
We also noticed magnets on bottom looks like they were glued at one time to the underside of the fly wheel. Does anyone know if these magnets should be glued and also what should there spacing be. Any ideas why this fly wheel pulled off so hard?
2. Are there any critical things we should keep in mind when working on this project. We have never put a boat motor back together and I am sure there are little secrets people have learned. Is there anything else we should replace while everything is torn apart.
Also, a repair manuel from IBOATS was ordered today...Im sure that will answer some questions.
Thanks and awaiting opinions.
Still working on uploading pictures.....having difficulty.
