Glastron3.0GLP-C
Thread starter- Joined
- Oct 21, 2012
- 61
Re: Blown cooling hose between thermostat housing and circulation pump at 45 psi!!!!
The bypass hole at the housing is clean and perfectly round. I understand that if everything else fail I could either enlarge this hole or add a bypass hose using two T-fittings before and after the housing. But the system was not designed this way and this would be a temp fix that might set the system off balance with overheating at different conditions. I might try a brand new thermostat housing first because after all these years I see some rust. Not much but maybe it is affecting operation.
My C-model has a temp switch at top of the elbow which screws on a dead end hole. (no connection to exhaust or water). There is another plug that connects to the exhaust opening. I guess it is there to easily inspect if water is leaking into the exhaust passage. I have removed the elbow and run water through it. It is not easy to run ti backwards. However, one of the tests was to connect a hose at the housing thermostat housing and send the water outside the boat bypassing completely the manifold/elbow section. The pressure was still there. Note that the water was flowing free of visible bubbles.
The second diagram (later Glp-C)
