Rodbolt and other hotrodders, I,m doing long distance diagnostic for my brother a thousand miles away. He is buiding a hot street car for his kid. The engine was cleaned and honed but not overbored as it was allready 30 over. A summit racing stroker crank ,rods and pistons were installed. Aluminum dart heads, warm crower cam and hardened pushrods and assorted other hot rod parts were put in. The engine was run at 2 to 3 grand to break in the cam ,and all gauges for water,oil pressure ,oiltemp , fuel pressure, trans temp were OK. When the car was taken out and run, too hard I believe, it lost power. Due to the noise level, glass packs, headers etc,they didn't hear much and the drove it home. There was ZERO compression in two cylinders. #1 and#8 . Is it possible with the stroker crank and slightly oversized lower portions of the cylinder, the very shallow pistons got pushed sideways at the bottom of the stroke enough to collapse the skirts of the pistons and totally lose compression. He's sick to his stomach over what happened as this engine was BIG bucks. He hesitates to take it apart again but this is my take on the situation. I guess I just need someone else to concur on my theory of what has happened. nevjb
