blown head gasket
coal duster
I have a question for you guys how long will your cylinder take the Punishment if you have a blown head gasket and didn't know it ?
pnwboat
Re: blown head gasket
It's anybody's guess. There is no definite answer. I will say this....if water was getting into the cylinder (depends on how much), it probably won't last as long as if there was no water leak. If no water leak, then there's a possibility that no damage has occurred.
Frank Acampora
Internally, a blown head gasket will cause no cylinder damage unless water was being admitted. The main thing you need to worry about is if the burning gasses blowing through the bad part burn the mating parts of the head or cylinder liner. Then a new gasket will not seal unless you mill the head or deck the block depending upon which burned.
HOWEVER: If the head gasket was damaged due to detonation, then the piston or cylinder will be damaged and it is not the head gasket cause. SO: if you see a melting piston or a scored liner, it is highly likely that you had/have a carb running lean for whatever reason.
If the liner or head did burn, it will be obvious and you will see the damage. Black discoloration and deposits can be scraped away with a razor.
coal duster
thanks guys I didn't have any water showing intill this last time I took it out and I could tell something wasn't right so I checked #2 spark plug and it has some moisture in it I hope there was no damage I mix my fuel 50 to 1 and a little more oil added for more protection
