blown motor
bustedblock
I have a 93 200 efi, with busted block, will a 225 or 250 power head fit on a 200 lower unit?
Faztbullet
Re: blown motor
Nope as the 225 and 250 are 3.0 liters in this year range and yours is a 2.5 liter. What type of damage do you have??
bustedblock
Re: blown motor
There is a hole in the crank case cover on # 5 cylinder. Have not tore it down and split the crankcase to check for futher damage yet.
bustedblock
Re: blown motor
What can be done to the powerhead to increase the hp, assuming the powerhead is salvagable.?
Faztbullet
Re: blown motor
Not much really stock as you are limited due to ECU has no way to increase fuel duration. You can order a adjustable ECU and intake and get some more hp (20+) That engine should be putting out around 220 at prop.
