Re: Blown stator on 1982 90hp v-4
A rectifier diode can test fine with a low voltage as in most Ohms Meter, and yet fail at higher voltages and loads in use.
Remove the stator wires when testing rectifiers, leave the battery connected, touch post on the rectifier with a test light, if either stator post on the rectifier lights the light, then the rectifier is bad.
I am trying to understand how a stator could cause a double fire. The stator simply charges the cap in the box, it is the scr that is switched to signal the discharge by the trigger.
The old Force black boxes had a bad habit os developing a double fire on one of the pair the box controlled. The SCR would go bad, switching one cyl then BOTH then the first again, then BOTH.
I could see this happening on ONE BOX but I seriously doubt TWO at once. Not impossible but very improbable. UNLESS there was an outside voltage source (like switched battery cables for a heartbeat) or pulse that came in on the kill wire and damaged BOTH boxes. In which case I would be double checking that ignition switch to be certain that it cannot happen again.
Lastly, the epoxy potting on stators has a terrible history of melting, cracking from thermal expansion, yada, yada, yada. If the stator passes DVA Voltage tests I wouldn't worry about it, yet. If the stator will NOT pass DVA Test, then by all means, replace it.
If you do not have access to a dva meter you can cheat.
WARNING, Never, Never, NEVER< EVER attempt this test on a trigger, you WILL smoke it.
Disconnect the stator leads from the box.
Connect one terminal(winding set)to the battery ground
Connect the other terminal to your test light
Connect the test light ground lead to battery +.
The light lights and remains lit, that stator winding is probably good.
A broken winding will NOT keep a test light lit. Period.
Disconnect the stator winding from ground, retest BOTH stator leads with the charged test light, any light and the winding is shorted to ground. (BAD)
Repeat with each set of stator windings.
Actually triggers may be tested similar to this but only using a single flashlight battery and bulb (1 & a 1/2 volt)
