Blue Fin Sportsman 1900
jbcurt00
USA or Canada?
If US, then Dap Weldwood contact cement or Dap All Weather Outdoor carpet adhesiv
In Canada they may not be available, but there should be good alternatives.
Thasme
Awesome, I was able to get the DAP outdoor Carpet adhesive! Waiting on UPS to show up with more rivets, supposed to be here today but the snow may not allow that! Once I get them here I will be able to get the last floor pieces in, set front deck in and start consoles, or well finish consoles.
I am kind of unsure on the carpet install where to put seems etc... I guess one way to figure it out is to just tackle it and see how it comes out!
jbcurt00
Follow the directions on the can and apply the Dap in a well ventilated area. A respirator might even be warranted.
jigngrub
The best method for carpeting decking in an aluminum boat is to wrap the decking before installing it. Glue and wrap the individual deck panels so the carpet laps 2" around the back of the panel like this:
Then rivet or screw the panels in place through the carpet leaving the fastener exposed, this will allow you to remove your deck panels with having to rip up your carpet later on in case you develop a leak or have other below deck problems like livewell leaks and such.
With a little preplanning and measuring the exposed fasteners with add a detailed look ton your installation:
By wrapping the deck panels you will eliminate and joint/seams in the carpet that can wear, show through, and come loose after a couple of years.
JBC is right about the fumes from the carpet adhesive, read the precautions on the can label. Also pay close attention to the working temperatures for the adhesive written on the can.
A good carpet roller is worth it's weight in gold when installing carpet in a boat, I like this one:
http://www.homedepot.com/p/Roberts-Extendable-Floor-Roller-10-955/100012074
It will roll out any wrinkles and bubbles in the carpet and embed the carpet backing firmly in the adhesive for a more professional and longer lasting installation.
Thasme
Jig... Thanks for the pics! I will have to get a roller too. I am headed to the garage now to get some pics taken and ask for a little advice...I had decent progress yesterday and will be getting the consoles dry fit today! Freakin auto upload to photo bucket takes a while so maybe lunch time I can get them on here!
Thasme
Ok got some pics uploaded finally.
I have been wanting to do the bow section, top and sides of gunnels all in one continuous piece. I think its possible. Any thoughts?
Next is the front deck...The way I rebuilt was just like the factory had built it and I do not believe I Will be able to completely do it in one carpet piece. Would it be better to cut the carpet directly in the middle of the walkway and fold it down from the seat so the seam would be in the middle of the side's, or should I make it so its one solid piece on one side and seam the other side?
the goopy gray/white looking stuff is liquid nails.
Done with lunch headed back to work on consoles! Thanks for all the help fellas!
Thasme
Jig....I saw some of you're pics of your carpet and trim job on your boat...Is that just flat aluminum you used for trim on the edges of you're deck?
Anybody else have advice on trim? I would prefer to have a plastic or rubber type but haven't had much like finding any.
Woodonglass
I'm pretty sure JNG used aluminum angle for his trim but I'll let him confirm that.
Back 30 yrs ago when I was a Remodel Contractor I used Rubber Stair Tread Nosing like this...
I think you could modify it to use as banding around a Deck opening but...I think the aluminum would be a MUCH better choice. Gluing and screwing any rubber or plastic molding to a boat deck would be problematic in the long term, IMHO. The aluminum would be much easier and more durable. Water and the UV from the Sun over time would do bad things to the rubber and plastic.:blue:
