Captain Ollie West
Thread starter- Joined
- May 1, 2014
- 156
I have a 1992 19 foot Bluewater Cuddy. It has a 4.3 with an SE 116 outdrive. I am not sure of the gear ratio, assumed it is a 1.81. I will have to check the numbers when I get home. It came with a 19 pitch Solas 4 blade prop. It gets on plane quick with the 19, but easily over revs past 5,000.
I purchased a used Mercruiser prop to see if it would work better (48 49634 21). I tried it out yesterday. It took a little longer to get on plane. It would still easily over rev past 5K. I could cruise about 30 MPH at 3800 -4000 RPMs (indicated on the gauges) So maybe a little faster cruise speed.
Any ideas? Bad tach? Wrong gear ratio? What are others running with similar boats?
