- Joined
- Apr 17, 2002
- 71,512
Re: boat building materials.....
Ayuh,........ I'll Start,..............
Real World Here,.... Been Here,.. Done This,... Still got the Barge to Prove it......
Back in 98,+ 99,... I dropped a 4.3LX into my Starcraft 221 Islander.... The "Motor Swap" turned into a Total Refit,... As Usual.....
I built the New Transom out of the locally available P/T Plywood,....Reasonably Dry wood....
I cut the transom panels,+ glued'em up with Resorsenal glue,+ Clamped them together with a couple hundred Screws, which were removed after the glue set up....2" thick, 3 pieces... I then set it up,+ Soaked it in boiled lynseed oil for about a week on each side.... That all got bolted back into the hull with Many SSteel bolts,+ screws.....
The Cockpit Sole(No Floor, JB) was removed by drilling out the rivets,+ All the wood was replaced, which lead to the Bulkhead replacements(the Mahogany rotted out),...
The Deck, 1/2" P/T Plywood, was pop-riveted(3/16"Xlong) back into place, just the way it came from the lumberyard the day before, Wet....
I ran it a season just bare, then I painted it with Epoxy resin,+ sprinkled Sand over the wet resin,+ very light cloth I had,... After it set up,+ I vacuumed up the excess sand, I painted it with good old Rustolium battleship gray,...
It's a Great Fishing deck, but atad hard on bare feet, 'specially tender bootfeet like mine....
The Bulkheads I skeletonized with 1/2" aluminum conduit frames I welded up...
Some I left open,+ others I filled the void with 5/8" plywood I found laying around a jobsite, covered with upholstery vinyl of course....
The 10 year Update is,........
I repainted the deck a few years ago, trying to soften it underfoot,....
The Transom still Looks like the day I bolted it in,.... No Problems with the Wood, or Fasteners.....
Same with the deck,... The aluminum rivets are holding it together Way Better than any Screws....
The SSteel screws,+ bolts haven't been an Issue,... Even when I inadvertantly used the hull as a ground path,.... The metal disappeared at paint chipped areas, but the screws didn't present any problems......
My only Confession in this Refit is,............. I left the Foam in the hull........
It is the original 1974 Styrofoam,... Kinda like a foam cooler, only the little bitty 1/8" beads, are about 3/4" to an Inch BIG,.....It was laying there, caged in by the hull, stringers, bulkheads,+ deck(Great Drainage
),... Except for alittle oil staining, it looked,+ felt New......
Sooo,... I put it back in..........
(Edit,.... Just to add,... I did all this Pre-Internet/ iboats.com.....1st Big tinboat,+ merc. drive,.. Steep learning curve stuff)
PT.... well... it resists glass. and it resists water... and about any other thing you can pour on it... but... it only resists it for so long. then the wood will give and start to rot. You can glass over it.. but it's more like a band aide on an open wound... instead of stiches. Glass will stick to PT if the wood is roughed up like crazy. But glass will not bond to PT, it will not penetrate PT enough to become one with it. Even with a great glass job, because boats flex under use, the glass will eventually start to peel away off of the wood.
get ready for the controversy. as you no i am not an advocate of pressure treated wood. there is something about stainless needing to be in an oxygen environment.
