Re: Boat Cover: Waterproof and Highway Travel?
I have sliding snaps along the top of my windshield. And permanently mounted snaps down each side and along the transom. How difficult would it be to fabricate a cover in this style? Tools, expertise?
I used 3 mil plastic sheeting for making templates. then transferred to the desired material with the addition of 1/2" or 1" seam allowances (if sewing pieces together 1/2", if leaving for a folded and polyester webbing 1").
Tools...to piggy back what bruceb said, a good sewing machine (doesn't need to an industrial nor walking foot, but those help, just a decent one with all metal gears), snap kit (look at bruceb's pontoon cover:
LINK, post #3), snap installation tool (they make various type, I used the cheap plastic base with a metal mandrel, tap a few times with a hammer...female side), if you already have the snaps on the boat, you can eliminate the pop-rivets so you won't need a pop-rivet gun/tool? soapstone for marking, hole punch or soldering gun with 1/4" tip (or so?) for poking holes/sealing material in fabric/webbing , hot knife is using Sunbrella or any acrylic based fabric (I should clarify my previous post, with polyester based fabric, a hot knife is not needed; however, it should be used as it'll keep the fraying to a minimum!).
Patience and an extra set of hands will make placing the cover over the boat easier. Also, youtube :"cavco", he's got some really good videos (some an hour or better) and making covers, enclosures, etc...
Good luck and as with all DIY projects, we need pictures!!
~Brett
