Boat dipping one way
jbabcock
Hi all I have a 14' tempest fiberglass boat with windscreen and steering ect... for some reason when throtled completely out the boat pulls hard to the left and dips down almost completely to the water when this happens the only way to right the boat is to trottle way down and countersteer hard also when it does this the boat almost feels as tho it is sliding across the water much like a car hydroplaning ive tryed all i know to balance the weight in the baot to no luck any ideas????;)
royal0014
Re: Boat dipping one way
I honestly don't know the answer, but it sounds like something is not lined up. Maybe the motor is loose and kicking sideways at full throttle, ie full torque. Just a thought........
abarron
Is you boat over powered? The torque of you propeller can do this if your over powered, Is your trim tab adjusted right? you may have to adjust it.
pinellas50
My boat did this when I first bought it. Turned out the problem was the hydra foil that the previous owner had on the motor.
jbabcock
not sure if its overpowered it has a 40hp johnson but the motor is early 60,s also the keel was just repaired but it has been doing this prior to it happening and the hydrofoil is the one thats on the motor the only thing i can think of is the motor at full throttle is lifting the front end too far out of the water could this be possible
Lrider
Pictures?
By the way, did you get this issue taken care of?
Hey all
I have a 1060's evenrude 40 hp motor and it dosnt seem to have a properly fitting prop i would like to get a new one but need to know what the proper pitch of the prop would be. Im just using the boat to fish out of in small lakes and Bays if this has any bearing on it i dunno im also not towing anyone or anything just need to know what the right prop pitch would be for this.
Thanks
James
jbabcock
actualy no i didnt get the prop question ever answered i still have that evenrude motor as well as the johnson the johnson seems to have a bit more punch with the same prop but yea there both pretty worn so any info on that would be great as well
Chris1956
Jbabcock, If you still have the performance issue, I would recommend you put a long straight edge on various parts of the hull near the stern(both sides of the keel) and see if the hull has "hook" or "Rocker". Both can happen on those older hulls, and cause the issues you see.
You might try to tilt the motor up one hole as well. Normally the second hole from the bottom is for most hulls. You might try the third hole to see if it is better.
jbabcock
thank you for the advice all ill give this a shot thursday when its not pouring rain or at least not supposed to be anyways and once again thank you for the tips.
