SilverSS07
- Joined
- Jun 13, 2012
- 266
Hey guys. I have a 1975 Bonito 15' tri hull with a 1973 50hp Mercury Thunderbolt 500. I'm new to working on outboards but not new to working on engines
. I took her out for the first time a few weeks ago and it would bog and die at anything over idle so I rebuilt the carbs and ran all new fuel line. Also put in a new set of plugs. Took her out again yesterday to adjust idle mix and she'll plow now but when I give it more throttle to attempt to get up on plane it revs up some for a few seconds and raises the front end some then starts to sound like it's bogging down. Sounds like it's flooding to me. If I don't pull back on the throttle it will die after maybe 5 seconds. Sorry I don't have a tach yet but I would guess it's revving up to around 2500-3000 rpm when attempting to accelerate; no where near peak RPM. I replaced the prop on the boat with a new one that had the same pitch- 13. Checked spark today with a timing light and it has spark on all cylinders. Ran a compression test also and it came back 110, 110, 105, 100. The next thing I plan on doing is rebuilding the fuel pump. It has 2 6 gal plastic day tanks that have fresh gas in them mixed 50:1 and the vent is open. Also she revs up fine in neutral and starts instantly cold or hot and runs fine until you try to get up on plane. Thanks for the help!
