Boat Hop .. Motor height ??????
Maximerc
Re: Boat Hop .. Motor height ??????
I have had my daughter at 70 pounds and my golden retreiver in the nose and it still porposes. I had 4 girls about 70 pounds each in the nose and it was not as dramatic but still wants to porpose. The X height is 1.5 inches above the V of the hull. I have a hard time beliving that this boat jumped like this when new. why any one would accept it like this is beyond me. I really want to do whatever I can to correct it. Trim tabs are my last resort. I just want to make sure that everything has been looked at befor I do this mod. I added the hydro plate to the engine.. hoping for a improvement , I might say it planes a bit quicker but no diffrence in porposing. there is nothing in the back of the boat that does not have to be there. Fuel tank and battery. Hey silly question do fuel tanks have a baffle in them ? 18 gallon remote tank. cant believe that would cause such incessive hopping though. Also I would worry about the gas charged shock trim tabs pushing down when the boat is not moving. If I beach in the weeds or sand they may get torn off. I know a lot of you out there run in "big " water but I run in all sorts of water. Lakes rivers resevors. (even my pond) I have read too that a diffrent prop may help (mine is a 12.25x21) SS 3 blade. I would truly be amazed is a 4 blade would help that much (or any for that matter) Sadly I do not have funds to just try it.
Jdeagro
iboats.com Partner
Maximerc;<br /><br />I do not know that the 1.5" is enough to cause this much of a problem. I think the 1.5" height issue would be better than having it lower. Given that you do get some help with the girls up front, I still think it is a balance issue. Let us talk off line to aviod discussing specific products. We are south of Cleveland by 12 miles. (jedeagro@sbcglobal.net)
asgrinne
I've played with a ton of props on my 200 Ocean pro on a 205 Sundowner(Four Winns). <br />14 1/4x18 Raker SS Awesome Bow lift- Hole Shot WOW <br />14 1/4x19 OMC SS Decent Bow lift Ok-- Hole Shot. <br />OK <br />14x 21 SS No hole shot, No bow lift to speak of Top end great. <br /><br />You may want to see if you can get your hands on something like the 18 Raker and see what it does. I got prop educated this year.
catfish1
this is Dhadley's field of expertise, he can help you if you give him the info he needs, trust me he knows shiit! ;)
