Boat Horn Confusion
Tahoe-Q7
Hello All,
I'm trying to troubleshoot the horn on my 2004 Tahoe Q7. If I remove the horn from the boat and connect it to a 12V supply, the horn works. Using a multi-meter, when I press the horn button with the power switch on, I see ~12V so I'm assuming the horn switch is working correctly and I'm getting the correct voltage to the horn. When I connect the horn to the correct leads and press the horn button with the power switch on, the horn clicks (sounds like a relay clicking) but the horn does not work. Is there something I'm missing in my troubleshooting?
Thanks in advance.
check your grounds at the ground buss
cyclops222
Did the horn work for years ? Did you adjust the screw in the center of the horn to improve the sound ?
Tahoe-Q7
Hello All,
Thanks for the replies. I will triple check all of my connections and grounds but if I had a bad connection or bad ground, why do I get 12v across both leads?
Thanks,
Hello All,
Thanks,
because your volt meter doesnt pull any current.
tpenfield
You mentioned 'relay clicking' . . . perhaps there is a relay in the circuit . . . that is not working.
