flashback
Thread starter- Joined
- Jun 28, 2002
- 4,547
I have recently moved my boat to watts bar to a boat house that has a cradle lift. the boat that was in there before was a 19 ft. bass boat that might have weighed 1800 lbs. my boat is a 21 ft scorpion that weighs about 3600 lbs.. the lift motor and gears are rated at 4500 lbs.. this system is very simple, the worm gear turns a much larger gear that is attached to a 2 inch pipe going down the center of the boat house. as the pipe turns, the cables (4 cables one on each corner) go thru a 4 inch sheave and across to the pipe then wind up around the pipe to lift the boat.. the cables are 1/4 inch galvanized steel..most of the weight is on the 2 rear cables with very little on the front cables..since i know the capacity of the gear system is 4500 lbs, and capable of lifting the boat, I need to know if the rest of the system would be as equally as strong... I know you folks can't really make an accurate reccommendation, but any experience would really help. thanks Flash
