Boat id if possible
LKaras1
Thinking about getting this boat. Year and name are unknown. Anyone have any ideas? Thanks
gcboat
Re: Boat id if possible
Look on your transom - upper right side just below the rubrail. There should be a series of number's and letter's. If you have some it can be entered through this site:http://www.uscgboating.org/recalls/mic_database.htm
If there aren't any there the vessel is a pre 1972 and you'll need to dig a lot deeper into any info I have.
tashasdaddy
it could be anything. are there any markings, labels on it. i going to venture to say it's from the 70's.
LKaras1
Well I bought it. Its a Norris Craft. Needs a new interior, motor, paint and some other stuff. But for $50.00 I couldnt pass it up.
ezmobee
If the windshield is in good shape and see-through you got your $50 worth right there.
LKaras1
Let's just say the windows are there.LOL Heres a couple of pics. Can anyone tell the year? I enter the number into the link gcboat gave but it didnt show any records. It needs work but I like the older style boats. What ever they used on the transom is ugly but it seems solid but I will replace whatever they did.
tashasdaddy
the vintage of the bow light is the 60's. and the old air guide speedo. could be one of the first tri hulls.
tmh
That's a beauty.....IF beauty is in the eye of the beholder (and the beholder is blind)! j/k Good luck, you are basically starting from scratch so you can rebuild it how you want. For $50 why not if you like working on them.
ddennis
Will look sharp when done! Nice lines!
FFScott6
Hey that is a nice start... I too just bartered for an oldie. I believe it is an Aristo Craft very early 60's 16' wGale sovereign 60. last run 2 seasons ago.
here's my mine. I would enjoy keeping intouch with others "rebuilding" similar boats
i386
It's fairly similar to mine in construction. Shouldn't be too hard to seperate if you have to. It appears to have an integral transom/splashwell like mine but it's hard to tell from the pics. If so, it'll be a lot less complicated.
When I separated mine it was pretty well attached at the stern so I cut it to get it out. I learned after the fact that if I'd worked with it some more I could have got it all in one piece. Not only did I give myself a lot of unnecessary work to do, I'm really not sure if I'll be able to join it back together where I cut it without being able to see the joint. :(
Pics of mine
