Re: Boat is falling over!
dsiekman,
I just posted this at The Hull Truth, where you asked the same questions,
I doubt the "rolling" issue you describe is being caused by the Trim Tabs. When fully retracted, as they are now, the Trim Tabs should angle slightly up from the bottom of the hull. That way they have little or no contact with the waterflow and should not affect the boat's running attitude.
I think you may have the bow trimmed a little too far down with the outdrives, great for speed, but if the bow cuts into a wave a little too deeply it can cause what is called "bow steering" and pull hard to one side or the other with the boat rolling in the process. Some hull shapes are more prone to this phenomena than others. Try trimming the drives out a bit at a time during your next outing and see if that solves the problem.
Ok, on to the Trim Tabs;
It is unusual to loose that much fluid in the system. As you suspect there may be a leak in one of the actuators (rams). You can run the boat without the Trim Tabs for the rest of the season if a haul out is out of the question.
Were the Trim Tabs working prior to the last outing or were they working before that?
We can try filling the reservoir wit Automatic Transmission Fluid (ATF) and then run the Trim Tabs up and down 3- 4 times to automatically bleed the air from the system.
Use any type of Automatic Transmission Fluid (ATF). Don't worry about the exact brand or type - it will all work, and can even be mixed. To add fluid, remove the Lexan cover on the HPU, locate the "filler stack" in the left front corner of the reservoir. There is a round plug sealing the filler stack. Remove the plug and add fluid to the full line on the reservoir. Note: Add fluid only with the trim tabs fully retracted (up). If your reservoir does not have a full line, add fluid so the fluid level is about 1 inch below the top of the reservoir with the trim tabs fully retracted (up).
If they work then put both Trim Tabs in the full down position overnight. The Trim Tabs will retract by themselves if there is a leak in them.
If there is a leak in one or both, it is usually a very easy fix with the boat out of the water, the O-rings can be replaced in them. It's an easy DIY job for the average boat owner and takes about 15 minutes. If you need to replace the O-rings we can arrange to have them mailed to you at no charge.
I hope this helps. Let me know if you have any other questions.
Tom
Bennett Marine
