Boat Leak
Dukes on Sunday
have a 2005 Larson 260 Cabrio.
I've read a few posts that deal with water leaks; it appears I have the same problem.
I believe that water is leaking from the anchor locker/ windlass area. Has anyone experienced a similar problem on the their cabrio, and if so have you solved it.
Any idea how to remove the forward bulkhead in front of the berth?
any help would be appreciated.
cheers.
Texas Parrothead
Re: Boat Leak
Sorry to hear about your leaking issue and hope you get it resolved quickly and easily.
Had to post and comment on your forum name. Always good to see another Buffett fan!!!:)
Dukes on Sunday
Re: Boat Leak
thanks, big Buffet Fan as well.
Yup, actually met my wife at Dukes on a Sunday in Waikiki, so the name fit!
seabob4
Re: Boat Leak
On a lot of boats of your type, there is an anchor locker b/head glassed to the underside of the deck, then a "close out" b/head secured just aft of that to give the cabin a finished look.
Feel around on the underside of the deck to see if you have any gaps. If so, laying glass over the gaps creating a fillet should seal them off. You should have only one hole at the base of the locker for draining...
