JimS123
- Joined
- Jul 27, 2007
- 8,371
Is she level before you get in, but with the gas and battery aboard?
Yessss. If it IS level and it only tips after running, then the tabs are causing the problem because they are improperly adjusted. Raise the tabs up out of the water and try it again.
If it tips like you say at the dock with the engine off, then you have a hull problem.
Maybe you need to be more definitive about the issue with engine on and off so we can truly diagnose it better.
