boat motor ground
readynow
I have a brand new Suzuki 40 on my aluminum boat. It was professionally installed
With both battery terminals off, I have continuity between the large black wire and the hull of the boat.
Is this normal?
I thought nothing was supposed to be grounded to the hull.
thank you
cr2k
Re: boat motor ground
Things are grounded to the engine and thru the mount it will be grounded to the hull.
Is this normal?
thank you
Ayuh,... That's normal,...
Ya can't run a live wire to an accessory, 'n then let it take a ground path through the hull to the motor, to the battery...
The accessory Much have it's own ground to battery wiring...
