Boat motor novice in need of help removing shift linkage to drop lower unit.
kawadude300
I'm trying to drop the lower unit and don't know where to detach the shift linkage. As you can see I am a boat motor novice, but I have always found a way to do it myself with the help of others. Thanks for any info. Mercury Ser#1680135
RICKRICK1
Ensign
Re: Boat motor novice in need of help removing shift linkage to drop lower unit.
What size motor, do you have a manual, what have you done so far?
kawadude300
It's a 6hp twin. I've got the lower unit dropped about an inch and it's getting caught on the shift linkage. A gentleman told me to find a 7/16's nut up top and remove that. Which I found the nut but it's very hard to even get a wrench on it. I did notice a grub screw on the shift linkage down by the lower unit. I'm worried about the nut up top because of the gears. I know once I take off the nut that the gears will clank all over the place. Is there an easier way to remove the linkage? And no I don't have a manual unfortunately.
