gunnymartin
- Joined
- May 30, 2009
- 6
I have an I/O mercruiser 3.0l 4 cyl that will not start. I am really new to boating, but cars I know (I only say that because I understand engines). The straight 4 wont turn over. The battery clicks the starter pushes and the whole engine rocks 1 time on the mounts, but that's it. I'm used to the starter turning it over several times until the sparks ignite and the engine runs. If I hold the key in the start position it will hold the engine in the rocked position like the starter is trying to turn the engine over and it won't go. Then if I let it off the engine falls back into place. It's like something is seized between the starter and the engine..... I tried to drain some oil and put it back through the engine because it's been sitting a while. Of course the guy who sold it to me said it ran fine. It's been winterized and sitting for about 2 years. I tried starting it with the earmuffs on and the garden hose running to save the impeller..... someone's advice to check it before the maiden voyage. Bottom line all I get when turning the key is the engine rocking up about a 1/4 inch, the crankshaft turns about 1/4 inch and it holds as long as I hold the key over. If I let go it goes back. Somethings stuck. Advice?????????
