Redneckboat21
- Joined
- Apr 18, 2008
- 75
Hey i have another question if the boat says that it will take the 10W30 oil can i buy the oil that i put in the car i can put in the boat or does it have to be marine oil?
Inform yourself too!...NOTE: The use of non-detergent oils, multi-viscosity oils (other than as specified), non-FC-W rated synthetic oils, low quality oils or oils that contain solid additives are specifically not recommended...........
This crankcase oil recommendation supersedes all previously printed crankcase oil recommendations for MerCruiser gasoline engines. The reason for this change is to include the newer engine oils that are now available in the recommendation.
i run this oil in my merc i/o
so what is FC-W and do i have to have that for my boat and where would i be able to find that at
no i have not read that yet i was just wondering because i have an 1989 valvo penta
http://www.volvo.com/volvopenta/glo...ice/publication_search/publication_search.htmRecommendations
Engines
Find recommended lubricants and information on how much oil you should put into your engine and/or drive in the chapter ?Technical data? in you Operator's manual.
