Boat outboard input
JREBASS7568
Looking at a glassstream(1988) in very good shape but no outboard. My question is with my lakes having limited power would a 20-30 hp outboard be good enough and idea on what kind of speed?
matt167
Tin StarCraft would be my suggestion. You’ll go as fast as the powers that be want you to. Hp limits have to do with shore line erosion
mr 88
What's your definition of " good enough " ? If not being able to get it up on a plane and top speed of 10 mph ,then yes ,it's good enough . For the hull to perform adequately you should be within about 80 % of the rated hp . More info ,other than Glassmaster ,might help , like length , beam ,weight, material hull is made out of , payload anticipated and what your speed expectations are .
roscoe
If 6 mph is fast enough.
On a wide 14' aluminum utility boat, a 30 hp will get you about 25 mph.
???----How big / heavy is the boat ?-----How fast to you want to go.-----A 6 HP motor can move a 10,000 LB boat, but not very fast.
