Texasmark
- Joined
- Dec 20, 2005
- 15,037
So, v-hull are define as the "V" at stern (looking at the rear of the transom, as in 2nd picture below) or at bow (looking at the front of the boat)?
Is "dead rise" define as in the first image below?
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/www.dadmarine.com\/tranangl.gif"**[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/cimg0.ibsrv.net\/gimg\/www.thehulltruth.com-vbulletin\/990x360\/24_degree_deadrise_angle_big_red_ugly_d514d829ffa31d8258e09a8ddd0155756bdd30ce.jpg"**[/IMG2]
No. First picture is transom angle which varies as do other boat dimensions. Your second picture is how you measure Dead Rise. If the center of your second picture were flat rather than in an arc it would be a "Pad hull". The Pad is like a water ski...small surface area, reasonable to high dead rise hull that usually accompanies a pad, gets the hull out of the way so that the spray off the pad won't contact the hull and slow you down....... normally found on bass boats that easily run 60+ MPH with 200 HP mils. For the pad to work you need to be up over 40 mph. Gotta have incoming water pressure to do the lifting of the hull and that takes MPH. The idea is to reduce the hull to water resistance by reducing the amount of hull in the water.
