boat plug
sikz3
My boat plug is a brass or copper plug that screws into the hull. It is the same type plug used in plumbing applications and my question is could I buy and use a rubber plug?
tashasdaddy
Re: boat plug
you can but they won't last long and the threads will eat it up. go to HD or Lowes plumbing dept, and get a brass plug.
Re: boat plug
Ayuh,......<br />It Should be a 1/2" Brass Pipe Plug............<br /><br />Although I have seen 3/4" Brass Pipe Plugs used in a very few applications........1/2" is by far the Most Common........
studlymandingo
Re: boat plug
I keep a couple spares onboard; they don't float, and they are very cheap!!!
jch7450
Re: boat plug
" Hunny, did you put the plug in? My feet are getting wet!"<br /><br />OHHHHHHH Cra--p! :eek: :eek: :eek: <br />yep I agree with Studly, there cheap, Buy the marine version
sloopy
Re: boat plug
keep one of the rubbers on board, if something happens it will be a lot easier to screw in of them in, than it will be to screw a brass one. I usually keep one extra rubber plug and 1 extra brass. Keep an adjustable wrench in your small (under five pounds) tool bag to tighten it.
