Boat plug
dspikes
I have a G3, and the only issue I have is with the plug. There is very little room to work with, and the end of a regular plug ends up where bilge pump wires and other things are in the way. Does anyone know of a T-handle drain plug that has about a 6" handle? Or maybe an extension tool that will turn the T-handle? That way, I could install the plug and twist it tight without having to deal with wires and stuff that is in the way. Thanks!
Earl Cordova
I don't know what a G3 is, but can you insert the plug from the outside of the boat?
dspikes
G3 is the make of boat. The only reason I dont put the plug in from the outside is that I'm in Louisiana, and a lot of our bayous have stumps and underwater cypress knees, etc, and I'm afraid of something pulling the plug out. It came with a wired plug on the jnside.
KJM
If the threads for the plug extend to the outside then just put in a regular type plug with no T handle, on the outside and use a wrench to tighten it. Nothing can hook that and pull it out.
