- Joined
- Mar 8, 2009
- 44,283
I've never done this but my thought would be to get an angle finder like this
Place the finder next to the transom and see what the angle is, then place it on the forward edge of the leg. The difference between the two angles is the angle you need to make if flat. If after the wedge is installed and it plows to much, the motor can be moved out with the pin.
That said, I can only find one manufacture and that's T-H Marine. They sell on which is one inch thick and changes the angle 5 degrees. Walmart also sells them online
http://thmarine.com/transom-wedge.html
