Boat Project - 1986 Cee Bee Avenger Fish and Ski - Will it plane out?
Bassn7
I bought a 50 HP 1980 4 cylinder Mercury for this 18 foot boat. I have a whale tail on the motor and I am going to install trim tabs... will it get up on plane? I am not worried about speed, I just fish.
roffey
I'm thinking yes, with just you in the boat. I would hold off on the trim tabs and see what is does with just the whale tail. For sure it will not be a speed daemon, LOL.
wrvond
Without sparkles, I don't think it has a chance. ;)
That's a nice looking rig, I'll bet you don't have much trouble, just put all your gear on the port side to counter balance your weight and you are good to go.
gm280
The usual issue most go by is to use an engine that is at least 70% of that listed max HP on the boat sec plate. That will give you a plane-able boat and run nicely as well. It won't be any speed streak, but it will work by that percentage. If you go less then that, it could be iffy to plane out. JMHO
Texasmark
If my grandpaw could plane out a 16' planked flat bottom skiff (very heavy) with a 1949 10 hp Johnson (he had to sit in the middle seat to do it while alone) with 2 kids in the boat, plus tackle and gas, you can plane that boat. I agree with "roffey". Don't spend money till you feel you need to.
Other thing is getting the right prop. That 50 should top out at 5500 rpm with your usual load. If you have a tachometer, great. You'll do best propping for that rpm or slightly below. It will help in your getting on plane (hole shot) and your engine will run cleaner and longer without having to lug.
If you don't have one set the engine (if no Power Trim and Tilt) to the tilt pin setting that gives you the best wide open throttle operation. Try different holes (tilt angles) till you find the sweet spot.
Then test the hole shot: Dead stop idling in gear to on plane, with the bow dropping back down. If not in the 5-10 second range, you might consider dropping down to the next available pitch prop, usually come in 2" increments. Your prop should be stamped with the pitch or a part number which you can google and get info (usually). iboats sells them and they have a tutorial about props and all. Look under Boat Parts and Accessories at the top of this page. Alum props are a lot cheaper than trim tabs and a lot easier to install. Grin.
Keep us posted.
Starcraft5834
as others said, get right prop... a 4 blade would probably help push it out of the hole... I would think that 50 will plane out that boat....just barely :)
