boat pulls strongly to the right
neilhifi
Hi, I am a novice boater and new to this forum so please forgive me if this is a stupid question.<br />Why does my speed boat pull to the right?<br />I have an 18 foot Spirit 180 powered by a <br />Mercury Black Max 135. I have done the anode thing to both extremes and it does not make a difference. Last year the engine had a new trim motor fitted which necessitated the engine being removed and put back, since then I think the pulling to the right problem got worse. Any suggestions?
eeboater
Re: boat pulls strongly to the right
Welcome aboard neil! Just thinking outloud here.. does anyone know if a bent skeg would do this? I may be totally off base...<br /><br />Sean
stevens
Do you trim the drive sufficiently out so that the bow does not ride too low? If it is too low, it may be causing what is known as bow steer.<br /><br />That trim anode above the prop is best left pointing straight back until you know what causes this behaviour.
D
DJ
Guest
It is not uncommon for someone to mount/remount an engine crooked.<br /><br />The trim tab SHOULD help.
studlymandingo
When you say you moved the trim tab from one extreme to the other, did you try all points in between? It doesn't take much to correct the pulling.
Gary H NC
Are you running a hydrofoil fin? If so take it off and re-test..
KRS
Banned
Swim ladder down?<br /><br />It reads like the problem started after engine remounted, they may have skewed it.
neilhifi
Thanks for your suggestions guys. I'll set the anode centrally until i figure this out. I'm not running a hydrofoil fin. I'm going to get a pro boat engineer to come out with me and give his professional opinion...I'll let you know the outcome.<br />(The swim ladder is up btw!)
farginicehole
My boat used to pull very hard due to the torque of the 150 hp outboard. I raised it up about 1 1/2 inches on the transom, and it now handles like a completely different boat! Very little pull at all now. It also got my WOT rpm up into a more desirable range.
