achris
More fish than mountain goat
- Joined
- May 19, 2004
- 27,468
Re: Boat running bad!!!!... Won't hit full rpms!!!!...
Use an advance timing light. You dial in the advance, and when the timing reaches that advance, it shows the initial advance on the marks (ie 6BTDC). Dial in 26 degrees on the light, and when the engine reaches 2000rpm the timing marks would show at 6BTDC...
Sounds like the carb needs a clean, or the fuel filters, or look for an air leak (section of clear hose in the fuel line just before the pump will show that up nicely).......
Adjust the throttle cable anchor point (Just behind the carb) back a bit...
Chris.....
Thanks! I noticed when I changed the timing I got ticking sound from the engine. Kinda hard to judge the advance because the marks only go to 12? but I'm sure I can eyeball it.
zildjian29 said:It help the boat a little bit now I can get over 4000 rpms but something still isn't right! It doesn't stall so easy while giving throttle but when wot it kinda revs up and down a little.
zildjian29 said:And my idle sticks a tiny bit it doesn't like to got back down to regular idle unless you tap the lever by the carb!!!!.....
Chris.....
