Hwsii check this out. I have a 17' Mark Twain that runs 34 at WOT(4800) with a 19 pitch prop and from previous experience seems like it should be a little more. Here is the answers to your questionaire for a prop recommendation.
1. 1975 Mark Twain 170VBR
2. 17'2'' x 84 wide 1750 lbs with motor
3. 140 HP
4. 2 people with 18 gallon of fuel
5. Crusing--Pulling tube
6. 23 degrees deadrise
7. 1974 Mercury 1150 ELPT 115 HP
8. 1.7 gear ratio
9. 4800-5200
10. Not a bass boat--not sure if pad bottom
11. Has Doelfin
12. 13x19p prop--no maker
13. 4800 rpm with 2 people and 18 gal of fuel
14. 1010 feet Lake pool level of lake used all the time
15. Full tune and carb rebuild 2 months ago--no change in speed before tune
16. Since last year
17. Still has full paint with no chips seen
18. Maybe a little more speed 42-44 mph
19. Will get info next time out
The boat handles and sounds good when on plane which occurs around 20 mph. If you have other questions I will get info for you
Thanks
3. 140 HP
8. 1.7 gear ratio
9. 4800-5200
11. Has Doelfin
16. Since last year
Thanks
