Brian Drew
- Joined
- Jun 15, 2009
- 14
I own a 120 mercruiser engine with a 3.0 mercarb,engine starts no problem at all,but when started it's automaticaly in reverse,it won't shift out of reverse,it won't shift into foward nore nutrual,shifter does move though,if you try to change it into foward the engine will just cut out,same with reverse when trying to accelorate wi'll stuck in reverse,I recently pulled the "U" shaft drive from the bellhousing unit,
replaced the gasket where they connect,now could I have messed with something on the shift shaft and also could I have done something wrong while putting the "U"shaft back into place?I also rebuilt the carb,but I am very sure this is not the carb,ran the carb manualy and runs fine.
