carrie laws
Thread starter- Joined
- Sep 6, 2023
- 10
Ok im losing my mind hope someone can help, heres the story. Got a older boat for a great deal its in great shape in and out and motor looks so clean. But its been sitting for a few years. Knew it would take a lil work to get it going , but did new plugs, oil change, new fuel filter , and new thermostat, battery she had a lil old gas could not get siphoned so put fuel cleaner in it and seafom and new premium gas in. After a couple attempts she fired right up and purrs like a kitten, idles great , starts on the turn of the key and sounds perfect. Problem is after 20 mins on the water throttled the motor shuts off , will run fine on muffs though
. like the key just shut off, no sputter no warning, then after about half hour or so it will start up or if i use starter fluid after a couple trys will start , Changed ignition coil, distributor cap and rotor, checked for water in fuel or gunk in filter there is none!! Changed the filter on carb, it had some debri in it but that didnt change the problem either , changed the fuel line from hard line to a rubber one thinking it was getting hot and vapor locking but it still shuts off while driving, What else could it be. Also another thing is my rpm guage says its at max. But the engine clearly is running at the right rpms. Maybe thats a bad rpm guage not sure. And not sure if that could be causing this issue??? One other thing when i got the boat it had no battery so when i put the new battery in. I hooked the black cable to negative and red to postive but i have 3 other cables not sure where they go??? One is all black i put that on the negative terminal found that was my issues to why all my lights and horn didnt work, but i dont know where the other two cables go. When i test them they seem to be positive , but im reading different answers of what these colors are , one cable is black with a yellow tip. One is black with a blue tip???? Could these cables not being hooked up be my problem. I will attach pic of cables. Somebody help????
