boat storage
hotmerc
does anyone know of any web sites that gives instructions on how to block a boat for winter storage. i've got such a big driveway i figure i'll save some money rather than keep it in a marina. i know i need cement blocks and blocks of wood and a couple of floor jacks. i'll be blocking it off a friends trailer.<br /><br />thanks
Seaboo2
Re: boat storage
Are you talking about blocking up the (whole) trailer or the boat off the trailer? Either one is not that hard. The whole trailer you simply jack it up and place blocks around enough to suport it and keep the tires off the ground.<br /><br /> The boat is a little more complicated (first I have to ask why bother???? I'd just leave it on the trailer myself and cover and winterize it).<br /><br /> If you do a search on this site it has been explained (in god detail) a couple times before (I'm sorry I didn't keep the link).
zzzzz
Re: boat storage
hmerc-rather than concrete blocks,you may be able to get the closed cell foam blocks-the kind they use on concrete homes for non-load bearing arches etc that then get stucco coated...you can sculpt them to hull shape and no danger of damaging hull :cool:
nomad317
Re: boat storage
I was going to post basically the same question. I have a heated garage but the trailer is too long. I searched the topics but I can't find any specific info. I (guess I) need to "block" the boat off of the trailer. Figured I'd just reply here as opposed to starting a new topic...<br /><br />Thanks<br />-nomad-
zzzzz
Re: boat storage
nomad-if you only lack a couple feet you may be able to convert trailer to have a removable neck with sleeve and bolts..this has worked for our customers numerous times :cool:
nomad317
Re: boat storage
Thanks ZZZZZ,<br /> I'd have to measure it again but I'm guessing it's at least 3 feet (maybe 4). It's an unusually long trailer for a 17'8" boat. It's suppose to hit freezing tonight and of course I was not ready for that. First winter owning a boat (can you tell) :D <br /><br />-nomad-
zzzzz
Re: boat storage
everybody has to have a first boat/first winter thing-mine was a 30 footer at Lake Erie..."whadda ya mean $1200 winter storage bill??" :eek: :eek: :eek:
hammlfam
Re: boat storage
Nomad, I'm from Indy area as well(noblesville). What are going to do about the freeze thing this week? I'm putting mine in storage at the marina and getting it winterized, but not for another 2 weeks and I can't get it into the garage. I'm going to wrap the motor with a comforter. ANother poster suggested putting in 100watt light bulbs with the engine.
nomad317
Re: boat storage
hammlfam,<br /> I wouldn't worry too much. It's a prolonged freeze (deep) that will kill ya. You should be fine for 2 weeks. The weather report just reminded me that I have a boat sitting in my driveway and I need to start planning. Light bulbs would probably work pretty good if you're worried. <br /><br />I don't even want to know the cost of winterizing and storage in a marina.<br /><br />I'm way too cheap for that stuff. :D <br /><br />-nomad-<br />"man overboard"
Seaboo2
Re: boat storage
Just a quick rundown (from the what worked for me files). The easiest way I've found to do it is to lower the tounge jack as low as you can. Block up the stern of the boat. Raise the jack to it's highest posision and block the front(you can also place them around the hull as needed at this point). I've also heard of people using tires (they kinda form to the hull). Yiu have to use some careful thinking, cussing, friends, and watching pulling out the trailer. I just think that using a jack on a boat it is too easy to punch a hole in the hull for my taste.
hotmerc
Re: boat storage
well, the trailer doesn't belong to me, which is why i'm blocking it. here in new jersey its 45 degrees. my boat was in the water last year till the first week in december and the river had a thin coat of ice on it. i think i'll come out a little early this year...
