Boat Switch Diagram
hounddog65
Does anyone have a diagram or know where to get one for a 1989 bayliner boat switch that has push in choke on it? Cant get my gauges to work on it. If someone could help i would appreciatte it. Thanks, hounddog
Silvertip
Re: Boat Switch Diagram
Don't start replacing things unless you know they are bad. That's a poor, and expensive way to troubleshoot. The gauges are all interconnected and power to them is from the "A" (accessory) terminal on the ignition switch. Use a test light or voltmeter to see if you have power on the "A" terminal when the key is on. If there is, the ignition switch is not the problem. If there is no power on the "A" terminal, check the "B" terminal. This terminal gets power from the battery via the engine electrical harness. But if that terminal has no power on it the engine wouldn't crank. Follow the wire to the first gauge in the string and measure again. Keep following the voltage until you lose it. If you have +12 volts at the "I" terminal on all of the gauges, then there is probably a bad ground. Use the ohm meter to verify this. If the meter shows open circuit you found the problem.
P 0 P E Y E
Good tips Silver,
If you don't have a test light or ohlm meter, try a jumper wire from a known batt and then jump the ground on the gages with a known ground.
