Boat Track (rail) System ideas?
haulnazz15
Re: Boat Track (rail) System ideas?
. . . listening to you out loud: You could also try increasing the spool diameter to increase the speed at which it moves. In the end, how fast do you need it to go? Turn it on to drop it in, it might take a minute or two. During that time: have a beer, check that the transom plug is in, tell fish stories, etc! :)
jeeperman
Thanks for the link Jeeperman....yes "McGuyver it" or "farmer rig it", are the correct terms.
The reason for the two cables is it is a 'push/pull' system not gravity. It's a loop where you need a pulley on the water end of the track.
The reason for the double spool is to 'hold' the cable.
Yea, I get the need for the pulley ut at the lake end in order to get the push and pull.
But I see no reason for the two spools. As it is, one spool would provide the same (actually better) traction for the cable on the spool as the two spools shown. Think of a capstan winch in that there is only one spool and the cable wraps around the capstan more than once to get the pulling grip needed. The two spools are the same size so there is no reduction going on either.
The only thing I see the second spool doing is to accommodate excess cable.
jeeperman
Thanks BigPrairie,
I've figured out that a 1.5hp motor 1750rpm with a 80:1 gearbox is sufficient up to 15% with a 3500lb load. 15 feet per minute.
I've found the individual electric motor, pulley, bearings, remote and such and buy the time you get it.....it's a toss up between that and a complete product winch like superwinch or warn. (I won't need more than a 50 foot remote distance so that's all fine)
It will come down to finding a deal, but at this point looks like either will work....the big draw back to the super and warn is the slow feed....2 feet per minute on a full load and empty spool. If I do a push/pull system I could keep the spool at the same diameter and tweak that to optimize the speed.
....thinking out loud.....:D
You could also use a small pto type winch. Or really any winch even if it is 12vdc and constructed in a way that you can pull the 12vdc motor off and power it with an ac voltage electric motor, direct drive or via chain and sprockets. Controlled with the garage door remote components.
rbh
I believe that do to the fact that wire rope is being used in a two block system, its more for grip than anything (wont slip), with a capstan head you need line preasure, as well as a feed that will not bunch up on rotation.
jeeperman
The rope is only touching half of the two spools, so the rope is touching the same amount of spool as if there was only one spool that the rope was wrapped around the same amount of times. right?.
In either case you still need the tension in order to get the grip.
rbh
"I think" the boat is the line weight, push/pull--in/out, but what can be seen is the way the wire rope goes through/around the sheaves, therefore not allowing bunching of the line, while capstand heads are great (pull lots of cable through conduit with them) but they would be a pain in the butt to operate in the same maner as the sheaved set up. Of course you could just call it a winch if you hard mount the line.
joed
Here's my track and how I get it in and out every year. Didn't have a picture of the dolley or the winch.
It's all 2x2x1/4 steel angle iron. Bolts together in 20 foot sections.
That's Lake Erie by the way.
Bluesmobile
I'm going to be building one in the next few days.
Materials(prices):
8 -10ft stickes of 3.5" EMT (craigslist $5 each)
30 sets of 6" bolts, washers, lock washers, and nuts (Axman $0.72 per pound)
1 -5ft 2" square tubing (menards $5-10?)
1- length of 1.5-2" angle iron (menards $5-10?)
1- length of 2" flat steel (menards $5-10?)
2 - beat up rims for boat trailer (?) havent found them
2 -trailer hubs with matching rims
2 -3" U-bolts
Boat trailer
Winch
Paint/grease
I plan on building a 30ft track with the emt and using two sticks of emt (cut in half) for crossbars. Cut brackets with the flat steel so that 4 bolts can go through the pipe. The fourth bolt will also hold a "L" bracket which connects to the crossbar. Paint/grease bolts to prevent rusting. Launch your boat then tie up at dock. Roll trailer down hill to water. Take off wheels and put on junk rims. Weld/bolt hubs to square tube and attach rims. U-bolt square tube to boat trailer. Chain winch to tree and attach cable to trailer. Heres a drawing of what I'm gonna do:
paulspaddle
Good deals on material....looks like a fun project.
I still have my eyeball out for parts and pieces, but as it turns out, a neighbour has this that I think I can get for the 'right price'. (the cost of tearing down the shed)
[/IMG]
[/IMG]
Bluesmobile
That looks like its in the ice or is it just me.
My grandpa had one that looked kind of like that but it was left in the water over winter by the previous owner a few times and the ice moved and bent it all to heck. Even after trying to straighten it, the dolly kept falling off the track all the time. We still have it but when I asked my grandpa about it he said "I don't want to see that in the water again" so I've started to create my own. I plan on trying to take as best of care for it (if it works) as I can.... well same goes for the boat but you understand what im saying.
Good luck with that track. Let me know how it turns out.
dan t.
the solution for the wheel bearings and water is--eliminate them. find a buddy with a lathe and make up a bronse cone that duplicates the dimentions of the wheel bearing ,cap the hub and install a grease nipple,pump the hub full twice a year and dont worry about it
Bluesmobile
Got it together. Still missing a pair of u-bolts for the front axle. I'm still suprised that the 3.5" emt can hold 400ish pounds. Also need a little paint for the brackets but otherwise all I need to do is toss it in the water. Btw, it weighs about 320 pounds...
Oh and yes the track is backwards compared to the boat. The jack is keeping the boat from rolling down the track when these pictures were taken.
paulspaddle
Hey cool job Blues! Using a trailer is a great idea.
Update again how it works when you instal it.
Bluesmobile
got it set up last weekend. 30ft of track (25ft in the water, 5ft on shore).
I'm alittle worried that it might not be long enough for my boat to lift off the trailer. At the end of the track is only about waist deep. I designed this so that when I pull the boat up, the front wheels will lift off the track and either roll on the ground or on some boards. If I have to extend this, I will extend it by another 20ft (10 in the water and 10 on shore).
I'll be testing it out this weekend to see how it works.
Me greasing the bolts
I put a pole out at the end with orange tape so that other boaters wont hit the end of the track. For some reason they get pretty close (found a couple lures on shore last weekend (way up on shore) grandparents aren't too happy mainly cause they normally get stuck in the canopy for their pontoon lift)
paulspaddle
Nice!...looking forward to seeing it in action....
Bluesmobile
okay. I believe that I need to build a carriage cause the trailer makes the boat sit too high. To get it off the trailer I need to put the motor in reverse 3/4 throttle, hop in back and bounce/rock/jump the boat. I don't really want to add to the track and put it out deeper, plus it kind of sucks to get it on the trailer. It was worth a shot right?
HI,
I will be doing a very similar build to what you crated with the round tubing in a BC lake.
I wanted to find out how did you join the tubes end to end? I see a type of collar, Can you explain what these collars are please? PVC? or steel and do they have a trade name or part name that is easily identifiable...
Cheers ET
achris
More fish than mountain goat
Hi there ET, I just wanted to let you know that since the thread you pulled up out of the archives is almost 1 year old and while looking back at Bluesmobile last activity date, he hasn't been online with iboats since then, so chances are he's not going to be coming back online to be able to provide you an update anytime soon. Below are a few reminders of iboats policies that we hope our forum members will try to follow along with as much as possible. Thank you & good luck with your new to you engine.
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Do not write in them. Even if it's to add more value to them at a much later date as it becomes confusing.
2. Old threads should be considered archives and used for reference only. Do not reply to them.
3. Do not take over someone else’s thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s thread. And those answers will be specific to your particular issue.
6. If you do need information relevant to an archive thread, please add a link to it in your new thread.
Thank You for your cooperation
The Moderators.
Fun Times
HI,
Cheers ET
Hi there ExtraTerrestrial, welcome to iboats!:)
While we're happy that the information inside this thread was helpful to you, you may have missed the red banner near the bottom of the page asking you to Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
For more information on future postings, please see iboats policies in the following link. Announcements - Mercruiser I/O & Inboard Engines & Outdrives
Also if you would like to try getting the original posters attention about this thread, you would have a better opportunity at sending paulspaddle a private message since his last Activity on iboats was back on May 14th, 2012 03:16 AM. If paulspaddle email is still in use to him then sending him a private message may get his attention sooner since he has his Send Notification Email When a Private Message is Received set to yes while Bluesmobile is set to no.
Thank you and good luck.
iboats Mod team
