jim j geezer
Thread starter- Joined
- May 16, 2012
- 189
Can't find a brand name, so I'm having a problem finding replacement bevel gears for my small boat trailer's jack.
With gear cover in place. Ignore that crank handle. I just replaced the loose bolt that had served that purpose.
Gear cover off and showing broken gear teeth
Both gears are 1/2" bore
These are beveled at 45 degrees
1-3/4" OD
~1/4" smooth surface where tension pin secures gear to shaft
~3/8" gear surface
15 teeth per gear
Can someone point me in the right direction to find a source?
1-3/4" OD
~3/8" gear surface
15 teeth per gear
