My running lights on my trailer continued to blow a fuse in my truck even when I increased the amps on the circuit from 10 to 20 amps. The turn and brake lights work, only running lights circuit affected.
Decided to try to isolate the problem by disconnecting the main rear lights of the trailer and then reconnected. The problem just vanished and the smaller amps worked. Hence, I decided it was a dirty connector so I've cleaned the connectors with alcohol and scrapped them with steel wool. I reconnected, while taping the connectors to keep them dry.
Any suggestions as to any other maintenance that I should perform?
