jodylee289
- Joined
- Jun 11, 2007
- 4
I have a 1987 procraft with 110 hp evinrude vro oil injected. What the boat does it will plane off some time but not all of the time. I have done a compression check on all four cylinders and the compression is about niney to ninety five on all four cylinders. I have read many threads saying that it could be in slow mode, but i dont have any alarm. possibly bad alarm horn. I have disconected both of the temperture sending units and the boat still does not run right Are there four or two of these sending units? I have sprayed carb cleaner in both carbs and even ran stp in my boat. Still no luck. Sometime the boat will plane off other times it wont. it is a very intermintent problem. I am confused it seems to want to run when there is no load on the engine When i turn the wheel all the way to the left or right the engine will rev up from a dead stop because there is little load on the motor then. Any help or suggestions would be helpful. I manage a automotive service department for pep boys, and excell at cars, but this boat motor has got me puzzled
thanks jody
jodylee289@msn.com
thanks jody
jodylee289@msn.com
