JaseBosto
Thread starter- Joined
- Mar 17, 2010
- 389
Everytime I've been on the water, it wasn't long till I got stressed out, and right about now I feel like sinking this boat.
Now the issue:
When I go to start the boat, it is difficult to start, cold or hot. It wouldn't run well at all. Meaning, it would idle ok, but when you try to plane off, it would lunge forward like it wanted to, then die out. After that, its very difficult to start. Most of the time it wont. I have to dump a tiny bit of gas in the carb to get her to fire up. After that, it will run but anything over idle and it dies. I have already had the carb rebuilt(and it is a thing of beauty now), replaced the fuel line, check ball valve, water separator, and fuel strainer in the carb. Fuel strainer in the tank was clean. Spark plugs, cap, rotor, coil all replaced.
No effect on the problem......! Any ideas? My chick stood by for over 4 hours today while I wrenched on this boat at the marina trying to get the problem solved. Eventually I got sick of working on it, and just putted around. I gave her a pat on the back and said thanks for hanging in there. IT was not fun, and hot as hell.
Now the issue:
