Boat will turn to the right by itself, propeller issue?
BoatAddicti0n
Can anyone please advice is this might be related to the propeller?
The symptom is that the boat, by itself, turns to the right (while the steering is straight).
I obviously have inspected the zinc anode fin and engine: everything seems to be aligned.
Also have checked the Teleflex/steering system which seems fine.
The boat is a Swedish Ryds 495 GT (16"), aprox. 320 kg unloaded, powered with Johnson outboard 60HP 1988 3cyl, original aluminum propeller (probably 12 1/4x15), which shows the signs of years of use, but does not seem destroyed.
QC
Re: Boat will turn to the right by itself, propeller issue?
Yes, actually it is a prop issue. Single Props turn only one way, makes stuff want to go the other way, or the same way depending on what stuff we're talking about . . .
You don't inspect them, you adjust them . . . ;) Here is an FAQ that will help. Without power steering be aware that fixing one pull might lead to a different pull at a different speed/RPM. Changing props can change this dynamic as well. The best you can get is a decent compromise based on the way you run your boat.
BoatAddicti0n
THANKS A LOT for the lesson!
boatAddict0n
Integration&Verification Engineer
#### Complex problems may have simple solutions ####
Rscardina
did you adjust the anode fin ? you can adjust that to counter the direction and make it less pronounced..might help a bit...
jimmbo
Are you refering that when you center the steering wheel straight, like in your car/truck, the boat is trying to turn to the right. Or are you refering what happens when you let go of the steering wheel?
