Boat Wire Color Coding
toneeees
Administrator
RedDC Positive ConductorPositive Mains
Black or YellowDC Negative ConductorReturn, Negative Mains
Green or Green w/ Yellow StripeDC Grounding ConductorBonding System
Bonding Wires (if insulated)
BrownGenerator ArmatureGenerator Armature to Regulator
Alternator Charge LightGenerator Terminal/Alternator Auxiliary Terminal to Light to Regulator
PumpsFuse or Switch to Lights
GreyNavigation LightsBonding Wires (if insulated)
TachometerTachometer Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator Output and Accessory Fuses or Switches
Common FeedDistribution Panel to Accessory Switch
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instruments
Instrument FeedDistribution Panel Electrical Instruments
Brown w/ Yellow StripeBilge BlowersPositive Mains (particularly unfused)
Yellow w/ Red StripeStarting CircuitStarting Switch to Solenoid
TanWater TemperatureWater Temperature Sender to Gauge
Green/Stripe (G/x)(except G/Y)Tilt Down and/or Trim InTilt and/or Trim Circuits
Blue/Stripe (Bl/x)Tilt Up and/or Trim OutTilt and/or Trim Circuits
Thanks to Ancor by Marinco for providing the chart. Photo by Shandchem.
