Will Liston
- Joined
- Jul 9, 2013
- 19
So I've been restoring a 1969 17.5ft Glastron Tri-Hull. It has a 1980 80 HP Mercury 4cyl engine. The motor at first sight was it decent shape but after I dug deeper it had all sorts of issues. I've changed all sorts of stuff and it's almost 100%.
Here's what I've changed:
Stator
Trigger
New Switchbox
Rectifier
4x Coils
Harnesses
Spark Plugs
Spark Plug Wires
Impeller
Cleaned/Rebuilt the Carbs and adjust float levels
Fuel Diaphragm
After all that the motor starts on first turn of the key. It Idles like a champ however when under load it doesn't appear as if gas is coming out of the high speed jets in the carbs at WOT. The carbs are cleaned and spotless. If I pull the carb off and blow through the fuel line with my mouth gas blows out of both jets. If I'm going with the current I can kinda get on a plane but the boat only goes 12-14MPH. The boat is not waterlogged or anything.
I'm stumped. The fuel lines aren't obstructed. I don't have a tach but it definitely doesn't sound like its hitting the right RPM's. Could this be a timing issue of some sort? An over propped situation? All ideas are welcome...
Thanks,
Will
Stator
Trigger
New Switchbox
Rectifier
4x Coils
Harnesses
Spark Plugs
Spark Plug Wires
Impeller
Fuel Diaphragm
Thanks,
Will
