boat won't start
bloxhamboy
Re: boat won't start
hi douglloyd, isn't that frustrating when people don't know what they're doing so that they have to guess the solution, especially something like this that can be checked for sure if they're defective or not. my mechanic doesn't seem like a poser he just doesn't understand electrical testing. i don't know how or why electricity works but when i build an addition on somebodies house i can wire it and make it work. when rodbolt and googieman try to explain it to me i get lost. if people don't understand how something works they shouldn't charge to fix it. problem is i don't know where to take my boat now, i guess salt lake city is only 2 1/2 hours away. i'll let you know how the saga ends
bloxhamboy
hi googiemman, thanks for your comments, before i took my boat in i would try to start my boat in my shop, when it wouldn't start i would pull a plug and hold it on the block and have my wife turn it over, i got spark on every plug. thats what sounded funny when he said i only had spark on 1 and 3?
FrenchFry
Remember me something... see my post on pulser coil some minutes ago
Only this small problen but I had no clue what the trigger was doing
And Yamaha mechanics made me change the coils going to spark plugs, then the stator, then talked about changing the CDI, etc then I decided to figure it out myself, it took some time since I am not an expert
Check first the pulser coils, it's easy
bloxhamboy
thanks for your comments french fry. i got tired of worring about my boat so i got my other boat and went fishing, i caught 7 sturgeon below american falls dam, it's part of the snake river system and sturgeon are strickly catch and release. but what a hoot, they were mostly 4-5 feet long and fantastic fighters. pretty ugly though. anyway thanks everybody for your comments and advice
rodbolt
actually, if you so called mechanic is factory trained AND using the 1986 115 manual there IS a test for the CDI using the yamaha pocket tester(ohm meter).
doesnt work but its there.
fastest most accurate is to simply test inputs and outputs with a peak reading voltmeter and its done.
do a forum search on a home made spark tester and make one.
FrenchFry
In my case the problem was a kind of vicious.
I and mechanics did not make the tests as suggests Rodbolt, probably we would have then found the problem
But for example with basic tests, everything looked fine at spark plug side (like tests with your wife)
And at the end it's sure the problem was only one pulser coil, maybe working by intermittence before it dies completely, same thing can happen with the CDI I assume
bloxhamboy
hey Rodbolt, i have a repair manual written by Seloc and as i look at i see a number of tests that you can apply to troubleshoot the ignition system. it tells how to check the cdi with resistant tests and how to check the pulsar coils etc and etc. it even states that it is best to follow this routine so you don't end up buying parts you don't need. i know i have taken my boat to the wrong place, i just hope i can get it back without having to buy a whole new ignition system. i have printed some of your reply's and will have a list of questions for this guy and there will definitley be some negotiations on his price. a good electronics guy would be worth his weight in gold. thanks
bloxhamboy
hey rodbolt, i pulled out my repair manual by Seloc and chapter 6 is full of ideas how to troubleshoot your ignition system. it tells how to check the cdi, pulsar coils and etc and etc. when i settle up with this guy i will have your comments and a bunch of questions for him. thanks
bloxhamboy
hey rodbolt, i was thumbing through my repair manual by Seloc and it has quite a secton on testing an ignition system, from testing a cdi to pulsar coils etc and etc. it says to do that so you just don't go puchasing parts you don't need. i wish i understood electricity better. a good electronics man is worth his weight in gold. i have printed some of your responses and i will have some questions to ask my mechanic when we settle up. thanks
rodbolt
electricity,for the most part, is simply water in a pipe.
water pressure = voltage
water flow = current.
water leaks=shorts
water restrictions,like a kinked hose= opens or bad connections.
the US taxpayer spent just over 300K teaching me electronics and troubleshooting.
in return I spent 6 years in the USN and was retired with a service connected disability.
Ill call it even.
my first 3 years in the USN I never saw a ship, they just kept telling me do good n this school and we will send ya to another. so I did.
and they did.
now I fix boats for a living cause for the most part its easy on the body and doesnt require much smarts.
but I am FC2 retired, not bad when I joined the US canue club as seaman recruit dumb bass and in just under 3 years was being paid as FC2 dumb bass.
google NEC 1121, my secondary NEC I was working on was harpoon missle, but my primary was 1121.
its whats on my DD-214
bloxhamboy
hey rodbolt, i called my mechanic today to check in and he says were still waiting on parts. i guess his supplier is waiting for a shipment of cdi's. crap! waiting on parts. you're right my repair manual by Seloc has a whole chapter on checking cdi's, pulsar coils, etc, etc. now if i just understood it i would do it myself
bloxhamboy
something weird is going on, i write a message and hit submit and nothing happens so i write it again and everything comes up?????
bloxhamboy
crapola, i called my mechanic today and he claims were still waiting for a cdi to show up. is that part hard to find or do thay make it after they have an order? saturday is opening day for ducks and geese. this stinks bigtime
rodbolt
dunno, sometimes I wait for parts, today I was waiting for 1 washer to start reassembling a blown F350. did not come today
maybe tomorrow but the weather is gonna wash me out I think.
I just hope your tech was right, this time.
bloxhamboy
of course my tech will be right, he's yamaha certified???? we hammered the ducks this morning i even got a banded one. why will the weather wash you out?
bloxhamboy
still waiting for a cdi, i wonder if it came in and now he's looking for a pulser coil to get my boat running
bloxhamboy
great news, i got my boat back last friday. i called the mechanic to see if the cdi had come in and he said he just got back from testing my boat in the water and it starts and runs great. i said thats great it must have been the cdi? he said oh no it was the stator. the parts company sent him a defective stator and thats why it wouldn't start when he changed the first stator. how do you suppose he knew he had a bad stator? i really don't care, i will just chalk this up as a bad experience and never go back to him again. as long as my boat starts i don't care. he did charge me $450.00 for the stator and the freight to get it here, i suppose thats fair but when you get a different story about your boat each time you inquire. i really appreciate rodbolt and googieman and everyones comments and suggestions. hope everyones boat runs like they should!!!!
