Boat won't start
Will wilton
I have a 2000 Baja boss hammer 454 7.4 l MPI I've replaced everything new starter slave solenoid new alternator new battery new cables when I turn the key all I'm getting is a click at the starter and at the slave solenoid I cannot find the problem I also replaced the 90 AMP fuse on the starter sprayed and cleaned
When you hear the click have someone check if the battery cables get warm/hot
If they do, pull some plugs and check for water, might be hydro locked
Are you located near Texas or a place which got freezing temps?
How long have you had the boat?
Is your motor a Merc, VP or other?
Will wilton
I just had the boat in the water running a week and a half ago I had a problem with the battery not charging so when I went to replace the alternator I should have disconnected the battery first because it aren't I ended up replacing the alternator the starter the slave solenoid and the 90 AMP I know the motor is not seized and I know the start of works
Will wilton
Mercruiser 454 MPI
There have been a lot of busted blocks this season. From Texas, was just checking
Place a voltmeter on the starter post and ground. Voltage should be 12.5 to 22.7 volts. Leave meter on and turn key to start. Voltage should not fall below 11 volts
