Re: Boating the Upper Chesapeake
Thanks Scott. I just got lucky.
My mechanic had it running today. The starter needed a little "love" (he smacked it with a hammer) but he said it fired right up and sounded good even when cold. 155# in all 8 cylinders!
Skargo- too bad I missed you. I had to drive right past your shop so I figured I'd stop in and say HI.
Stacey said you'd be mad that she saw the Wellcraft before you!
solanabeacherman- Billdc and I are also Pa residents. Pretty much the same rules apply in Md, but I'd suggest you consider having a USCGA courtesy inspection next spring. They're free and painless. If you're missing a required item you WON'T get fined. Here's the actual checklist they use:
http://forms.cgaux.org/archive/a7012.pdf
As far as PFD's, the law only requires kids to wear 'em, but any responsible adult should set a good example and wear 'em when underway too! (just my opinion).
Alcohol: of course it's legal to have onboard. The problem is that in the event you're involved in an incident- no matter how minor- the authorities will ALWAYS presume intoxication of the operator if they see any open containers. You'd then be subject to a whole bunch of unpleasantness, from detainment to breath and possible blood tests. As an adult, you'll have to decide if it's really worth the risks. Don't get me wrong, I love a cold one (or two or three....) but I save 'em for AFTER the boating is done for the day.
Empty containers should always be brought back and disposed of properly!
Visual signals- they should've been covered in your Pa safe boaters program. I'd recommend you pick up a copy of 'Chapmans Piloting and Seamanship' and immerse yourself. It's good reading!
http://en.wikipedia.org/wiki/Chapman_Piloting
Ramps- Sure there's plenty but some require a county permit. Go back and read some of the earlier posts in this thread to get some ideas. BTW, the HdG Tydings Park ramp will be renovated by next spring and will be going up to 10 bucks.
