Boating the Upper Chesapeake
Blue Crabber
Ensign
The rest of the story!
So finally, I have a chance to type out the rest of the story! Soooo sorry for the delay guys, didn't mean to keep you waiting so long. Work has been crazy, the end of may is the end of our fiscal quarter so the powers that be want to see every penny possible sold! On top of that, my wife has been sicker than a dog for the past week so every spare second was spent helping her recover. Finally, its 1:30 in the morning and I have a few minutes to type this out, hopefully before I fall asleep, lol.
Alright, so I am sitting in the lower Delaware Bay with only one engine running, the admiral in the berth resting and the BIG surprise is not going at all like I expected. I still had 90 miles to go to get to our new home port. I had only covered about 10 miles so far limping along on one engine at 5 mph hour. I had decided that if I didn't have both engines running strong by noon, I would have to turn around and abort the trip. Picking the story back up at 11:30 am...
So far I had emptied and changed the water seperating fuel filter about 3 times, thinking there was water in the tank and blocking the filter thus preventing enough fuel flow to keep the engine running at cruise speed. Each time I did it, the engine seemed to run a little bit better for a little bit longer. But by the last filter change, it was obvious there wasn't any water in the fuel filter any longer, only good clean fuel. Finally, I went to the flybridge and started running the engines at different RPM's to try and figure out what was going on. The engine would run great from 1000 rpm to 2700 rpm. Any continued running over 2700 rpm and the engine would start puttering and if pushed long enough, would stall out. Seemed to reinforce the idea that the engine was starving for fuel. Finally a light bulb went off, what if the tank pickup tube screen is partially clogged and that is preventing enough fuel to flow through the filters. I went down below and moved the engine fuel line to the spare pick up tube installed in the tank. This tube was mounted in the front of the tank and would be used for the generator. (there is no generator currently installed on the boat.) Capped off the pickup tube that I was using, and went back to the flybridge. Time check, 11:43 am. Alright, this was my last option and last chance to fix this before abort time. If this didn't take care of it, I didn't have the capability to fix it on the water and would have to turn back. Start up port engine and she fires to life and purrs right along at 1000 rpm just like before. Slowly increase throttles to 1500 rpm, running strong. Increase to 2000 rpm, now we are pushing alot of water, still running strong. 2500 rpm, trying to climb on plane, just not quite enough power, still running good. So far my switch didn't hurt anything! Okay, time for the test, 3000 rpm. Boat climbs onto plane, rpm's increase to 3500 and she is still running strong, no hesitation, no hiccup, nothing, just running strong! Pull back to 3200 rpm and cruise for 10 minutes keeping my eyes glued to the engine sync gauge as this would indicate the engine was starting to have trouble before the tach would. Never moved a bit! So the last ditch attempt fixed the problem and she ran strong all the way home!!!!!!! I was so relived!
Went down to the berth to get my wife and she rejoined me on the flybridge, at the helm. Now this is what I had planned the whole time. A perfect cruise back without any problems. She was a little hesitant at first expecting the engine to die again at any time. To be honest, I was wondering if the same thing would happen. But with each passing minute and mile, we both developed more confidence in the boat.
The water was perfect for the trip back, just as I was hoping and planned on, one thing going right! (Thanks for the advice Arks) The visibility was much better at this point, but you could still see the fog around in the distance threatening to close back in, but it wasn't to bad. Slowly by slowly, we kept passing the waypoints in the GPS and adding more marks, tracking our location on the charts. We were cruising at about 25 mph at 3100 rpm.
The following pictures are from the Delaware bay, from the mouth where it meets the Atlantic Ocean, all the way up to C&D Canal. Look how flat the water was!!!! That part did work as planned!
Blue Crabber
Ensign
Re: The rest of the story!
Finally, the nuclear plant on the Delaware Bay! This meant that we were getting very close to the entrance to the C&D Canal. And hear it was!
Finally, we were in familiar water! I think both my wife and I let out a big sigh or relief, especially me! Don't get me wrong, I enjoyed the cruise through the Delaware Bay immensely!! Just in the back of my head I was running all of the worst case scenarios. What if we break down again, what if we run out of fuel for the port engine. I was now using the generator pick up tube which was mounted at the front of the tank and wouldn't extend all of the way to the bottom of the tank. (Done as safety precaution so that the generator can run the tank dry of fuel so you can start it back up and get to a fuel dock.) I just had no idea how low it went. But, finally, we were in the safety and security of the C&D canal. Now we were in protected waters and closer to tow boat US hailing ports. Plus it was getting later in the day and we wanted to get into the new slip in plenty of time to secure the boat before sun down.
Next, we stopped into Summit North Marina on the C&D Canal to top off the fuel tanks.
They are in the middle of replacing all of their floating docks and pilings! Huge project and it should be great when its done, just kind of a mess while we were there. Found our way to the very back where the fuel dock was and I pulled along side like a pro! Even impressed myself if I must say so. Took on 80 gallons of fuel. While there, we decided to grab some ice cream, very refreshing! Untie the lines and back into the canal.
Now back in the center of the canal, throw both throttles up to bring her up on plane and the port engine sputters again. Holy cow, now what!!!!! Go down and change the fuel filter, sure enough, refueling the boat stirred up some lose debris in the tank and it was now in the filter. Back to the flybridge, throttles forward and away we go! Big Smile again! I can deal with changing the filters after refueling until the tanks have a chance to flush all the loose debris out no doubt caused by the ethanol fuel.
A few more pics through the canal.
The time through the C&D Canal went very fast, before we new it we were passing the Chesapeake Inn at Chesapeake City
Blue Crabber
Ensign
Re: Boating the Upper Chesapeake
Alright, passed Chesapeake City, climbed back up on plane, 27 miles to go and we would arrive at Tydings Marina in Havre De Grace, MD. Bumped the throttles to 3400 rpm, doing just over 27 miles an hour. 1 hour to go. I couldn't believe how fast the last hour went!! I think it was mostly because we were in familiar water and could recognize everything that we were passing.
Before we knew what happened, we were down the Elk River and rounding Turkey Point Lighthouse. Did you guys know that this is one of the shortest lighthouse on the Chesapeake Bay but also one that can be seen for the longest distance? Makes sense since it sits so high on the point!
A big thank you to our good friends Scott and Stacey who through a surprise welcoming party for us in the new slip! Here is what the slip looked like as we backed in.
Scott is a good friend who knew about the boat purchase ahead of time. I sent him a copy of my float plan knowing that if something went wrong, he would be able to contact the right people. I kept sending him text updates through out the day letting him know of our progress. Great friends that will also be brining their new boat to our same pier soon as well! Can't wait!
Well, after meeting some other dock neighbors, we were able to get the boat secured in her slip and properly adjusted for the tide swing.
Then we grabbed dinner with Scott and his wife Stacey and told them all about our trip and just generally got caught up with them.
We made our way back to the boat and crashed for the night! It is amazing how tiring of a day it ended up being. We were both exhausted physically and mentally. A good nights sleep was had aboard the new boat in her new slip. Life is good!
So, would I do this again or recommend that anybody else do this? NO!!!!!!!!! It was not any fun keeping this big surprise from my best friend! I will never do this again!!! Although it turned out okay and my wife likes the boat, it still wasn't worth it.
2 weeks after the big trip, we had surprised both of our families with the boat and had them out on it. They all love it as well. So much for a quiet retreat for the 2 of us!
This past weekend we met a bunch of friends out on the water and rafted up. It was a beautiful day on the water and we had a great time! My wife really enjoyed the extra amenities of this boat, being able to take a nap during the day and having a head to use when needed as we were out all afternoon. Snapped this picture of the boat, one of my favorites!
Looking forward to a great summer!
ezmobee
Thanks for finishing the story Brandon. Maybe you could try a tank flushing type setup like Arks did at his house with his "new" Nova. The last picture there from this weekend is awesome.
bowman316
does every slip at tidings come with one of those white boxes? At my marina you have to rent one for 300 or 400 a season.
DBreskin
Rent for $400?! You can buy a small one for $400!
gn85
Great story! I've been lurking and learning, but I've really been waiting to hear how this story ended. Congrats.
Blue Crabber
Ensign
Again - sorry it took so long to finish! Hope you guys enjoyed it.
Bowman - they come with each slip, no extra charges.
Ezmobee - That's a great idea, I forgot about that. I have everything needed too. The only thing I think might prevent it from working is I think that refueling the boat stirs the stuff up and suspends it above the bottom. I am going to full up this weekend and see what happens. Thanks for the suggestion!
bowman316
did you have old dirty fuel in there to begin with? When you bought the boat, was there any fuel in the tanks?
I would wanna drain the tanks, and get any crap out that way.
Damifudo
Great Story BC and nice boat congrats! Beautiful pictures and given time I am sure you will gain comfort taking her on another long journey and when you do please post another report for us that dont get to adventure very far from home. Thanks again!
Jhudds
Blue Crabber,
You are officially my new favorite author! Great story! The story inspires and delights all us here on the forums. I hope you don't mind that we all just lived vicariously thru you and your adventure. I for one would love to do what you just did. Perhaps not the secret keeping stuff, but everything else. Good luck with Empty Pockets, she looks like a great boat.
iamcrabby2
Wow, I just blew an hour reading through this thread, awesome.
I used to live in North East Md. in the neighborhood you past just before the Turkey Point Lighthouse, but have since moved to Texas. Another great mechanic if you need one are the folks at Long Point Marina. The older gentleman that owned the place was a crotchety ole' coot, but more that once he'd load up parts in the basket of his bicycle and peddle down to the end of the dock to replace parts on our boat. I had a bunch of work done to my Sea Ray before I moved and I was thrilled with the work and the price. Haven't been able to find anybody as good down here.
Have fun on the bay this summer, I miss it greatly, especially fireworks and trips to St. Michael's.
Billdc
I'll be out around Sand Island on Sunday and Monday. And the Elk/Bohemia on Saturday, weather permitting. I don't even get the boat out of storage until Thursday, but it should be fine. If you see a black on white Campion bowrider stop and say hello.
Blue Crabber
Ensign
did you have old dirty fuel in there to begin with? When you bought the boat, was there any fuel in the tanks? I would wanna drain the tanks, and get any crap out that way.
They were mostly empty when I bought the boat. I didn't have any problems with them at all until after I refueled the boat half way through the trip. Right now I am hoping that means it isn't too bad and the refueling stirred some stuff up. I am going to refuel this weekend so I will find out what happens then. When I dumped the filter out last time, there was just a few very little specs in it.
Thanks! After that trip, I have pretty good confidence in it! Will spend the rest of this year local on the upper bay not wondering to far. I will keep going through the systems, upgrading, fixing, etc. Wife and I talked about doing a long trip on it next year for vacation. We will see what happens. If I do, I will be sure to post it here for everyones enjoyment :D
Blue Crabber,
Glad to hear that you enjoyed the story. Take it from someone thats been there and done that, don't keep it a secret!! I will never again.
Blue Crabber
Ensign
Arks - Really enjoyed seeing you at the marina last weekend! Hope that happens more this year. Are you going to be on the water at all this weekend?
My wife and I plan to be out some on Sunday afternoon with family and then if all goes well we will spend our first overnight on the hook somewhere in the upper bay. Should be out all day Monday as well.
bowman316
So when your going over the key bridge, on 695, there is a small island just to the south of the bridge. What is that Island? It is right in the middle of the bridge, maybe 500 yards south.
I read that it is the ruins of ft carrol, but I'm not sure if they are talking about the same island. Can you tie your boat off there, or is it off limits? I kinda wanna check it out.
DBreskin
http://lmgtfy.com/?q=fort+carroll
I don't think you're actually prohibited from going on the island, but I also don't think there's any safe place to dock or tie off and disembark.
arks
Likewise!
Don't know about this weekend.
If I'm around I'll try 'Empty Pockets' on 16.
Fort Carroll is a very interesting place. Never been out there but have thought about kayaking around it.
Here's an interesting write-up from a kayaker who visited a few years ago:
http://oceancolor.gsfc.nasa.gov/staff/gene/ft_carroll.html
Nice pics in that article.
And check out this picture: http://www.flickr.com/photos/avi8tor4fn/2290990070/
According to a post in that link the island is privately owned....
bowman316
I went out to Ft Carroll on Sat, and we eventually found a way inside.
I could not tie up anywhere, so I just anchored right next to it, and swam over. But after visiting it, i think I could have tied up to the small island, next to the fort, since it goes straight down off the edge.
So the bridge to get over to the entrance to the fort was gone, so we had to find a way to climb into a window. We finally got inside, and walked around the perimiter. The whole place was totally over run with birds, I almost got attacked by an angry momma bird.
Seems like that place should be turned into a museum, instead of just ignoring it. I wonder how they made it rise straight out of 20 ft of water. With no sloping sides.
Blue Crabber
Ensign
Spent a great evening and night on the boat Saturday and all day Sunday. Spent an hour anchored near Sand Island and watched the sun go down with some family on the boat. Then we spent the evening in the slip. Really wanted to spend the evening on the "hook" but decided against it as there was a big storm coming our way and we had our dog with us for the first time. (She hates storms)
Good news is that I learned some more about the boat over the weekend. While anchored out at Sands Island, I had a hard time restarting the port engine. Determined to be low on fuel, I knew I was getting low, but didn't think that low. Also, the port engine is still tied into the generator fuel pickup as the engine pickup was the issue on the way home. (Still neee to check into that) Was able to get back up on plane and slip back into the marina quickly before totally running out of fuel on the port tank. When I refuelled i put 52 gallons into each tank. Since I have 70 gallon tanks, that means that there should be about 18 gallons of fuel left after that point. So, when I get a generator intalled in the boat someday, if I ever run the tank empty with the generator on, I still have enough fuel to make it back to a dock somehere.)
ANother great thing was after I fueled up, the boat ran great!! I did NOT need to stop and change the fuel filter :D Hoping that means that any loose particalres in the tank have already been flushed out in the first fuel up!!
Did anybody else make it out this weekend?
